![]() | Home > Maintenance & Mods (L405) > aux belt/pulleys |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 346 ![]() ![]() ![]() |
@Gremlin500, That's good to know as I've got a SDV6 L494 and it will be due a pump as it's nearly hit 275K, mabye I'll do it when I do the belts for the third time |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 565 ![]() ![]() ![]() |
which dose makes sense as apart from engine size the pumps look very similar and the procedure is much the same ........there has to be someone who has had the oil pump replaced or is it that the sdv8 oil pump is the most reliable part on the engine ..hmmm .i dont know just going to go on collecting the other parts for now and see what happens on here |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1751 ![]() ![]() ![]() |
I’d be careful Will, I’m not saying the same procedure is OK for the V8 at all |
no im not going to replace the oil pump |
dose anybody know if this part (LR025988) which is from the alternator idler pully on the l322 fit the alternator pully on the l405 or do you have to replace the bracket ? |
I came across this when rebuilding mine and was a little annoyed to find it was the only idler you couldn't buy separately and had to buy the idler and bracket for £200+ L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
yea that's it, at the end of the day you just need the pully the bracket is never going to break such a rip off.......thinking about just getting it and take off the original pully and see if they are the same can always return it |
It's a different diameter to all the other pulleys on the 405, maybe worth a shot using a 322 version, I just didn't have the will to mess about so swallowed the cost with a bad taste. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
yea decided to get both parts and see if it fit and just return what i don't use .at least it will be some use to other ppl |
this is a part number for a pully that fits on the alternated bracket (febest 1287-ix55 ) ...a l405 user fitted this last year straight swap and has had no issues got one on order |
Good to know, I'll keep a note of that for the future |
hopefully this will help others too |
