![]() | Home > Technical (L405) > Possible Turbo issues |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
Thats great new Ian - fingers crossed for you - I wish you were closer to me..!
| iainvr4 Member Since: 15 Mar 2013 Location: glasgow Posts: 49
Had a further road test today and all ok up to 4K rpm and no issues. The valve from the faults codes which where the same as mine is the shut off valve bolted on to the back of the secondary turbo. The CSOV doesnāt have a position sensor so it wouldnāt know its position or if stuck but wonder if the MaF sensor faults is a sign of it sticking as it would cause a the passenger one to get a reading when it shouldnāt.
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
That's certainly the turbine shut-off valve, not the CSOV. L405 D350 SE Carpathian Grey D5 19" rims |
| Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173
Does anyone know if this was the case with the L322 4.4 2011 or introduced with the L405s? Thanks Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! š³ Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
Hi Gang,
Hi gang,
| marques.a Member Since: 17 May 2021 Location: Belo Horizonte Posts: 8
I didn't have time to read your entire thread.
I couldn't send the URL, for some reason it didn't work. |
The seconday turbo doesn't have variable vanes (nor a variable nozzle) and therefore doesn't have an actuator, instead using the turbine shut-off valve to control exhaust flow. L405 D350 SE Carpathian Grey D5 19" rims |
| All times are GMT |
