Home > In Car Electronics (L405) > Wireless Apple Carplay
AndyMal
United Kingdom 2017 Range Rover Autobiography SDV8 Baltic Blue
I have wired Apple Carplay and mainly use it for Google Maps. However, it frequently drops especially early in journeys and even if the phone battery is fully charged. Will using a wireless adaptor such as Quadlock or Carlinkit overcome this problem? I see from other threads that many have installed these; do you still experience drops in the connection?
Post #719768 14th Jun 2025 7:12pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Given the wireless Carplay kits are essentially just a bridge to the wired Carplay connection, I can't see how this would cure your problem. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #719779 14th Jun 2025 11:23pm
mk22
United Kingdom 2018 Range Rover Autobiography TDV6 Santorini Black
It would only solve the issue if the dropping out was being caused by your phone, i.e the lightning/usb-c port. If you had an issue with the port you'd see it with other wired connections such as charging only working when the cable is at the correct angle
Post #719801 15th Jun 2025 4:46pm
As stated above Thumbs Up agreed Thumbs Up
Post #719846 16th Jun 2025 1:49am
AndyMal
Thanks for the replies. I suppose my main hope had been that separating the phone charging from the carplay connection may prevent the drops. I'm not sure that is the primary issue so I'll save money and not go wireless.
Post #719956 17th Jun 2025 7:10pm
