![]() | Home > In Car Electronics (L405) > Wireless Apple Carplay |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
Given the wireless Carplay kits are essentially just a bridge to the wired Carplay connection, I can't see how this would cure your problem. 2016 Skoda Octavia VRS Estate
mk22 Member Since: 06 Jun 2025 Location: England Posts: 2 ![]() ![]() ![]() |
It would only solve the issue if the dropping out was being caused by your phone, i.e the lightning/usb-c port. If you had an issue with the port you'd see it with other wired connections such as charging only working when the cable is at the correct angle |
As stated above |
AndyMal Member Since: 13 Jun 2025 Location: Hampshire Posts: 2 ![]() ![]() ![]() |
Thanks for the replies. I suppose my main hope had been that separating the phone charging from the carplay connection may prevent the drops. I'm not sure that is the primary issue so I'll save money and not go wireless. |
