Home > Maintenance & Mods (L322) > Getting the driveshaft out of hub?
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Having a nightmare with this and would welcome advice!
Managed to get the nut off easily with an air impact wrench.
Waiting for decent ball joint splitter to arrive so I can disconnet the lower arms and steering tie rod.
What's the best way of getting the splined end out?
I've been hammering the flip out of it and I can't see it moving at all.
I'm thinking that a hydraulic puller might be best. Anyone used something like this?
https://www.ebay.co.uk/itm/167566125178?_s...R6aQldnvZQ
Post #719918 17th Jun 2025 12:11pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I used a manual version of that, took a bit of effort but it did come out, getting it back in again was entertaining though.
Post #719942 17th Jun 2025 4:47pm
dhallworth
What's the reason you're removing the hub from the car?
The first time I removed mine I took the hub and driveshaft out as a complete assembly. It's heavy but doable.
The shafts are known for seizing in the hubs and Land Rover make a tool to remove them.
Post #719950 17th Jun 2025 6:28pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
A pusher type tool is whats needed. Needs to be suitably large to fit. I got one off ebay but had to grind bits off it to make it fit. Worked fine.
A trick I learned here for reassembly is to drill and m8 tap the driveshaft end. You can then lever or slide hammer the shaft back through. It does pull through relatively easily but there's little or no chance of being able to just push it through no matter how clean and lubed it is. It's not an interference fit but it's very snug, and you don't want to be damaging the cv joint or boot, or you get to do it all again! Don't ask....
Chris
Post #719954 17th Jun 2025 7:00pm
Yes you'll need a pushing tool like the one on eBay... Similar to the JLR tool Thumbs Up
Post #719968 18th Jun 2025 2:31am
NDT
David.
Replacing the CV joint. After failing to do the boot properly last year…
Post #719971 18th Jun 2025 7:39am
NDT
Chris
Thanks - I’ve got an M8 tap somewhere so will do that!
Post #719972 18th Jun 2025 7:40am
NDT
Thanks all for the help. Will hit it tomorrow after the various tools arrive today.
Post #719973 18th Jun 2025 7:40am
Mikey
We tried the smaller hydraulic ones, but it struggled.
We've got one of these now, designed to be used with an impact gun. Never been defeated, but probably a little expensive for a 1 off use...
Post #719976 18th Jun 2025 9:49am
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Steve covered this very job on his channel with the hydraulic tool:
?si=QYMZxdXK320q82dM ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2024 BMW iX3
Post #719977 18th Jun 2025 10:39am
cass
If you've got a big SDS drill they work wonders in Impact mode
Post #719978 18th Jun 2025 11:54am
GRANGEROVER
Germany
I bought the 10t hydraulic version like the one in your link, with that it's a breeze to get the shaft out 👍
Post #719991 18th Jun 2025 7:31pm
