![]() | Home > Technical (L322) > Battery drain - 2011 4.4 TDV8 Range Rover |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 34 ![]() ![]() ![]() |
Hi, I can't help on the alternator fuse however, I own a 2012 4.4tdv8 and they are hungry for batteries. I'm not sure about your but suspect it will need an AGM type battery. I replaced mine for a Yuasa AGM and have never looked back. I do think the battery warning is too sensitive and priot to changing to AGM, found mine giving that warning on a regular basis.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7941 ![]() ![]() ![]() |
Yes, think Land Rover did an update to make the warning message less sensitive. Mine does the same.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3843 ![]() ![]() ![]() |
Big tip when changing the battery is to first remove the plenum filter box, only 2 minute job, but gives you much more room to work.
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 100 ![]() ![]() ![]() |
On removal and refitting, I take it you know how to get the bonnet into the service position, ie wide open?
QBee Member Since: 22 Jun 2025 Location: Newark Posts: 8 ![]() ![]() ![]() |
Thanks guys, great replies.
The starter motor turns over very fast, even on 60% charge, so I suspect that is not an issue.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 773 ![]() ![]() |
My 2011car that I’ve had for 10 years has chucked up that warning practically every time it hasn’t been used for a few days even with a new battery fitted.
Thank you, that is reassuring. It’s just the very large and speedy drop in charge state that now worries me.
I waited Two days and checked the battery this morning. 40% charged.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 838 ![]() ![]() |
The MY11 wasn’t designed to keep the battery fully charged at all times
Thanks Rambles.
Quick update. I left the car parked and locked and with my new battery condition tester I could see that my AGM battery went from 90% charged to 20% charged in 48 hours. It started fine, and the battery condition was good.
