![]() | Home > Technical (L322) > Battery drain - 2011 4.4 TDV8 Range Rover |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 34 ![]() ![]() ![]() |
Hi, I can't help on the alternator fuse however, I own a 2012 4.4tdv8 and they are hungry for batteries. I'm not sure about your but suspect it will need an AGM type battery. I replaced mine for a Yuasa AGM and have never looked back. I do think the battery warning is too sensitive and priot to changing to AGM, found mine giving that warning on a regular basis.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7943 ![]() ![]() ![]() |
Yes, think Land Rover did an update to make the warning message less sensitive. Mine does the same.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3843 ![]() ![]() ![]() |
Big tip when changing the battery is to first remove the plenum filter box, only 2 minute job, but gives you much more room to work.
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 100 ![]() ![]() ![]() |
On removal and refitting, I take it you know how to get the bonnet into the service position, ie wide open?
QBee Member Since: 22 Jun 2025 Location: Newark Posts: 9 ![]() ![]() ![]() |
Thanks guys, great replies.
The starter motor turns over very fast, even on 60% charge, so I suspect that is not an issue.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 773 ![]() ![]() |
My 2011car that I’ve had for 10 years has chucked up that warning practically every time it hasn’t been used for a few days even with a new battery fitted.
Thank you, that is reassuring. It’s just the very large and speedy drop in charge state that now worries me.
I waited Two days and checked the battery this morning. 40% charged.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 838 ![]() ![]() |
The MY11 wasn’t designed to keep the battery fully charged at all times
Thanks Rambles.
Quick update. I left the car parked and locked and with my new battery condition tester I could see that my AGM battery went from 90% charged to 20% charged in 48 hours. It started fine, and the battery condition was good.
Well, the issue is probably the battery. Even though it’s only 2.5 years old, it isn’t holding charge very well. Not helped by the L322’s epic ability to leak amps.
