![]() | Home > Technical (L405) > All I want for Christmas..... is a new Engine |
nike_bytom Member Since: 29 Mar 2025 Location: Kettering Posts: 13 ![]() ![]() ![]() |
Hi all,
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 384 ![]() ![]() ![]() |
As you say you cannot fix the proper mounting plate at the rear if the gearbox is still in the car, from what I can remember I just found a suitably strong point on the rear of the drivers side cylinder head and used that, sorry I can't remember exactly but pretty sure I didn't remove anything to 'free up' a hole. I didn't have the JLR brackets, so improvised (think the one I used at the rear was a Defender engine lift bracket that I had lying around. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Thank you, I appreciate your reply.
Just be careful with the primary turbo (drivers side) actuator as the engine comes out as it gets very close to getting bashed! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Yes, noted – I'll be very careful with that! I know getting a new actuator these days is a challenge. Right now I’m just clearing out the garage to try and make space for the engine stand haha. People always say I’m lucky to have a double garage, but it feels tiny when you’ve got a lot of cr*p in there!
AussieV8 Member Since: 04 Jul 2025 Location: Maitland Posts: 6 ![]() ![]() ![]() |
Hey Guys,
Not another!! Mine was a big end bearing as opposed to mains, I had no problems using the torque values i posted, however i used a new conrod as they can go oval from when they knock.
My main rotated about 10mm, didnt fully spin, thats what starved the big ends.
Got you!
Crank was toast, bought a second hand crank, its all std, itll just get a birthday, good clean and polish.
I assume you've used the std size mains?
I used the part number you supplied and got them from Turner Engineering
at the moment i have a set of std mains, and over sized bore mains both for STD crank. the trip on monday will dictate what we do there |
Oh ok, I seem to recall the bolts I had, had been out of stock and then they managed to get some but weren't bagged. The markings on them were different to the JLR ones.
