Home > Technical (L322) > 4.4 tdv8 Westminster reduced performance
Joff1961
Don’t think the old pipe would have lasted much longer
Post #720448 27th Jun 2025 1:58pm
Joff1961
Ok, next part of the story. So tonight I have put a vacuum onto the CSOV and nothing happens, does the arm have to be disconnected to do this with a vacuum as I did not take it off. Any help would go a long way thank you.
Post #720458 27th Jun 2025 6:38pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
No, it should move easily when a vacuum is applied. Is it pulling a vacuum but not moving, indicating a seized arm or not pulling a vacuum, which would be a faulty actuator on the csov. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #720460 27th Jun 2025 6:41pm
Joff1961
I got a vacuum of 1hg on it but it’s not moving
Post #720461 27th Jun 2025 6:43pm
4RRS
Seized actuator arm or more likely the joint on the end, does it have the early joint or the later modified part? Either way a good soaking with a lubricant should sort it out. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #720462 27th Jun 2025 6:45pm
Joff1961
It’s the later one with no nut on it, I’ve put a lot of WD40 on it tonight and I’ll have another go tomorrow.
Post #720464 27th Jun 2025 6:54pm
Joff1961
So it’s been a bad day. Took the car over to my mums this morning as I do every day to check on her. Car was not running well from start off, went into limp mode and after a few miles come up with DPF full visit dealers. Got home to find oil in the left had air filter, so looks like left turbo has gone. Think that’s it for me and car will be sold.
Post #720491 28th Jun 2025 3:36pm
