Home > Technical (L405) > 2015 vogue SE bought , a few questions
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
bought a 2105 l405 3.0 tdv6 with a snapped cambelt , now fully repaired and running sweet , halfway through the journey home i had to swap the battery to enable the indicators / wipers , since then ive lost rear tail gate function ( only opens half way ) folding mirrors on the key and the DRLs arent active ! ive done a battery recent and checked charging level from the alternator ( 14.1v ) is there something else i need to do ? the boot lid just beeps when it try to close with the button
thanks
simon
Post #720486 28th Jun 2025 2:46pm
Are you sure it used to work ?
Does the car have a second battery ?
It's worth checking the opening height calibration
It sounds like it might be an anti-trap issue
https://www.fullfatrr.com/forum/topic62567.html
https://www.fullfatrr.com/forum/topic67260.html
Folding mirrors - does that mean the car isn't locking or is it just the folding mirrors ?
Post #720492 28th Jun 2025 3:44pm
bembo449
hi pal , 2 things , where the main battery is theres a 2 pin plug without a home and i have a fault code Uo447-00 gateway A
are these related ? im not with the car so cant have a fiddle about unfortunately
Post #720494 28th Jun 2025 3:54pm
bembo449
i do have a 2nd battery and i will try the set procedure in the video , cheers pal
Post #720498 28th Jun 2025 5:21pm
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
Connector near main battery: https://www.fullfatrr.com/forum/post550039.html
U0447-00: This may apply to your car - https://static.nhtsa.gov/odi/tsbs/2014/MC-10101001-9340.pdf
Tailgate not closing: Has happened to me when the battery went flat. Make sure battery is fully charged. Open the upper tailgate all the way. By hand if necessary. Press and hold the tailgate close button on the upper tailgate for 15+ seconds.
Post #720523 29th Jun 2025 8:25am
