Home > Maintenance & Mods (L322) > Early L322 steering wheel gear paddle retro fit! Amazing!
Page 6 of 6 <123456
Weegie
I had the problem mentioned by David - Zebedee - and cured it with a spot of superglue. The brass switch is an interference fit in the composite block and, as he says, can slip so that the switch is not getting fully depressed.
Before sorting it I found that if I pushed siideways against the gear lever when operating the paddle it would work so that might be a way of checking.
Very smooth system which allows for imperceptible gear changes. Thumbs Up John
GAP iiD BT-Sold
Post #575071 4th Dec 2020 3:50pm
Danwilderspin
Right further update but still had no time to tear it down..
So 50/50 chance of working from cold but the other day it was working on a spirited drive and then the paddles
Just stopped working mod drive. Tried knocking to sprout and then back and to neutral and back no go.
Turned it off for a few hour went back out and worked again for a bit and stopped again...
Hmmm Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #576147 14th Dec 2020 6:22pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Hi Dan - I'll drop you a PM and we can get Damien to talk over the problem. He'll find the issue. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #576262 15th Dec 2020 5:07pm
damienwalker
Hmmm
Hi Dan,
We need to get this fixed for you!
It is almost certainly a problem with the yellow earth lead that is causing your problem (see Weegie's and Zebedee's comments)....we have experienced no other operational issues, and mine (and hopefully everyone elses!) works fine.
Please check that the little gold plated plunger on the yellow wire is protruding from the 3D printed block properly, that it is still spring loaded and that it touches the gear lever properly when in Drive. There is a small amount of 'slop' in the gear linkage which translates to a few mm of movement where the plunger touches the lever. If the mounting block is not adjusted properly (or the plunger is stuck/retracted), you could easily get a situation where the contact is intermittent and the behavior would be as you describe.
I'm very happy to discuss this on the phone if you'd like to give me a call.
Incidentally, the pocket in the back of the airbag where the Tx module fits is all plastic, so there should be no need to add tape or heatshrink to the module. I accept this might appear unusual, but it is quite happy in its little environment there. As you mentioned, the red lights flash when you pull a paddle so the Tx is working. You could check the equivalent red light inside the Rx box too but I would concentrate on the earth lead first.
Good luck.
D.
Post #576379 16th Dec 2020 7:27pm
Zebedee
Land Rover have finally provided some more of the genuine paddles for this kit (they've been on backorder for months), so once again they are available. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #657893 26th Feb 2023 8:08pm
MilesBFree
United States
Hi, has anyone fitted this kit to a 2012 Supercharged?
It has the stick shifter, not the rotary knob, which is what we all got in the US, I believe.
Post #697497 6th Aug 2024 4:05pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
The folks I got it from are out of England - and the years don't include that... but I think it would be fine.
The big thing is the lever depresses a plunger when in Drive that turns on the unit.
If you have the ZF6 then I would assume it would work!
I talk about it some in this video... About the [08:00] mark then again [18:20]
 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #697516 6th Aug 2024 8:55pm
MilesBFree
United States
Thanks! I think I might give it a go.
Post #697555 7th Aug 2024 4:53pm
Danwilderspin
It’s been a while but mines randomly completely stopped working. The plunger etc is still lined up - anyone else had this? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #697754 9th Aug 2024 10:47pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
My kit still works and that's after transferring it from the 53 plate td6 to the 08 plate tdv8 3..6 I have now and I use them quite regularly to either change up when doing 48 mph in traffic in fouth to fifth or down when braking.
Post #697763 10th Aug 2024 12:34am
MilesBFree
United States
Update: after discussing with @Zebedee in PMs, it sounds like the '10 - 12 cars may already have the wiring in place, at least on cars with the stick-type shifter we got here in the US. So I may only need to add the paddles and away we go! Or not Smile I ordered the paddles and they will hopefully arrive Friday - Monday so I will try it and report back if they work or not.
The next step will be to see if they work to downshift with the shifter in regular Drive (as opposed to needing to move the lever to manual). If the paddles alone will not allow it to work that way, it sounds like adding the kit would send the proper message to the transmission control unit so this will all work as described in the kit info above.
If there any errors in this post, they are my interpretation, not the info he provided Smile
I'll report back when i receive the paddles from the dealership and get them installed.
Note: I found they were about $10 cheaper each brand new with 12 month warranty from the dealer than a couple of people were selling used ones for on eBay, so don't rule put the dealer.
Here's a better/more complete photo of the shift lever on mine for reference
Post #698151 15th Aug 2024 4:10pm
kds2
Just the same set up as my 2008 3.6 tdv8 and yes you can go up or down the box in drive without moving lever over to sport as long as the gearbox is happy with it, ie. road speed and engine revs ect.
Post #698164 15th Aug 2024 6:52pm
Banana Jack
Another happy bunny
So happy to have found this magical little product. I installed my L322 Paddleshift today and it worked perfectly first time. Who'd have thought that my 21 year old car could still be improved - thank you so much Damien and David for putting so much time and effort into making all our L322 lives better. Now the only fly in the ointment is that I need to somehow fish out my 3mm allen key which decided to slide into one of the windscreen de-mister vents. Duhh.... Keep up the good work fellas!
Photos here: https://www.fullfatrr.com/gallery/thumbnails.php?album=5146
Post #720552 29th Jun 2025 3:26pm
Page 6 of 6 <123456
