Home > Technical (L322) > Suspension Error/Exhaust Valve Code but 4X4 screen different
Murakami
Ireland 2009 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hello
So... an error message appear on my L322 last week and when I checked codes, they were the same as when the exhaust valve/desiccant issue occurred in my Discovery 3. Ordered the kit and was about to undertake it today. However, the bongs are more serious now and I'm getting the warning not to exceed 30mph. I realise this is part of the compressor error as time passes, but when I checked the 4X4 screen, it shows the rear offside sensor lower than rest.
The clincher is that I can't find a code on the iCarsoft scanner (LR V1.0), it simply shows the exhaust valve code?
I'm under time pressure here, as I'm driving to France in a fortnight and don't want to lose time messing with it, when I might be better sacrificing the money and going straight to an independent?
Any help appreciated.
Post #721057 9th Jul 2025 9:16am
Murakami
The plot thickens...
When I removed the cover for the compressor, this cable had disconnected:
So having connected that, I seem to have lost the code and I have no warnings coming up. I drove around lifting and raising the suspension. No suspension fault message anymore but it can't lower and I ended up lopsided with the left rear at standard and the right lifted. So, I still think there's a height sensor fault there?
Post #721062 9th Jul 2025 11:18am
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Have you looked at the actual height sensor under the car? I think I’ve read before that the mounting can corrode and cause them to detach.
Post #721072 9th Jul 2025 3:20pm
mjdronfield
Happy to be corrected, but that looks like the front sensor in your info screen pic that’s lower…..?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #721074 9th Jul 2025 3:33pm
Murakami
Oh good god, you’re right. I’d better sort that order asap. How did I miss that.
Post #721079 9th Jul 2025 4:35pm
Murakami
On going saga… desiccant kit used and everything seemed to go smoothly.
Flashing red light 4x4 screen for front offside. Getting stressed as am to drive to France in a week and no specialist I ring has open slots. One did mention compressor may be faulty and not enough pressure to lift the front. Suggested I test the sensor by lifting that side of car.
Jacking it up did nothing. So I used a large rock and drove left front wheel on to it. No response on screen but I could see both wheels on the right “jiggling” when I drove that side over it.
Still hoping sensor.
Post #721141 10th Jul 2025 8:57pm
mjdronfield
Sensor has to be your first call as it’s not reading level when the car is level. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #721142 10th Jul 2025 9:05pm
Murakami
Agree. Considering it should also be a relatively easy fix.
Post #721144 10th Jul 2025 9:14pm
Murakami
So , in the end, I managed to pressure an independent into helping me, and he was very helpful and quick. The end of the story is that I simply bought a new compressor instead of wasting any more time. That was fitted easily and then it became clear the sensor really was done, so that was fitted and we're all ready for our trip now with fully working suspension. I'm not sure whether I messed up installing the desiccant or the exhaust valve should have been drilled, I opted to just play it safe due to the time constraints.
My thanks to mjdronfield for pointing out my error above as that really saved me a substantial amount of time and stress.
Post #721403 16th Jul 2025 3:40pm
mjdronfield
No worries mate. You got it sorted in the end. Sometimes if you are on a bit of a time crunch, you just need to get it sorted….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #721405 16th Jul 2025 3:56pm
