|  | Home > Technical (L322) > Suspension Error/Exhaust Valve Code but 4X4 screen different |
| Murakami Member Since: 08 Sep 2023 Location: Dublin Posts: 20      | The plot thickens...
|  9th Jul 2025 10:18am |
| Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 153      | Have you looked at the actual height sensor under the car? I think I’ve read before that the mounting can corrode and cause them to detach. | ||
|  9th Jul 2025 2:20pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Happy to be corrected, but that looks like the front sensor in your info screen pic that’s lower…..?
|  9th Jul 2025 2:33pm |
| Murakami Member Since: 08 Sep 2023 Location: Dublin Posts: 20      | Oh good god, you’re right. I’d better sort that order asap. How did I miss that. | ||
|  9th Jul 2025 3:35pm |
| Murakami Member Since: 08 Sep 2023 Location: Dublin Posts: 20      | On going saga… desiccant kit used and everything seemed to go smoothly.
|  10th Jul 2025 7:57pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Sensor has to be your first call as it’s not reading level when the car is level. 2011 Range Rover Vogue SE 4.4 TDV8
|  10th Jul 2025 8:05pm |
| Murakami Member Since: 08 Sep 2023 Location: Dublin Posts: 20      | Agree. Considering it should also be a relatively easy fix. | ||
|  10th Jul 2025 8:14pm |
| Murakami Member Since: 08 Sep 2023 Location: Dublin Posts: 20      | So , in the end, I managed to pressure an independent into helping me, and he was very helpful and quick. The end of the story is that I simply bought a new compressor instead of wasting any more time. That was fitted easily and then it became clear the sensor really was done, so that was fitted and we're all ready for our trip now with fully working suspension. I'm not sure whether I messed up installing the desiccant or the exhaust valve should have been drilled, I opted to just play it safe due to the time constraints.
|  16th Jul 2025 2:40pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | No worries mate. You got it sorted in the end. Sometimes if you are on a bit of a time crunch, you just need to get it sorted….
|  16th Jul 2025 2:56pm |
| Posting Rules
