Home > Technical (L322) > Britpart Inlet Manifolds
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Does anybody have experience of using aftermarket/Britpart inlet manifolds? I need a new one and the LR part is a staggering 1300 Euro. All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #721070 9th Jul 2025 1:09pm
Dolphinboy
be aware the inlet manifold part for the TDV8 4.4 was improved/strengthened after 2011/12 as the original was too weak to take 2 x turbo pressure .
Make sure you get the uprated version LR 034993. my 2011 TDV8 was changed in 2020 and the Left hand/pax inlet manifold alone was only £375 + vat. you will also need Injector kits x 4 @ £85 ea.
Edit - sorry just seen you have a 3.6 TDV8. must be different.
Post #721077 9th Jul 2025 2:59pm
Rudyard1
I have replaced both of mine on my 3.6 with britpart ones - pretty good quality and they’ve been fine 2007 Range Rover Vogue 3.6 TDV8
Post #721116 10th Jul 2025 10:34am
Rangerovermad98
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Hi rudy are these still going strong ? How long have you had them fitted ? Many thanks
Post #725564 3rd Oct 2025 8:00pm
Rudyard1
OS one went in 2023 and the NS one in 2024. Both still fine and to be fair, a good quality item. 2007 Range Rover Vogue 3.6 TDV8
Post #725569 3rd Oct 2025 8:55pm
Rangerovermad98
Thank you , I will go with Britpart then , can’t justify genuine
Post #725571 3rd Oct 2025 9:16pm
