![]() | Home > Technical (L322) > Britpart Inlet Manifolds |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
be aware the inlet manifold part for the TDV8 4.4 was improved/strengthened after 2011/12 as the original was too weak to take 2 x turbo pressure .
Rudyard1 Member Since: 15 Nov 2021 Location: Devon Posts: 123 ![]() ![]() |
I have replaced both of mine on my 3.6 with britpart ones - pretty good quality and they’ve been fine 2007 Range Rover Vogue 3.6 TDV8 |
Rangerovermad98 Member Since: 18 Mar 2025 Location: Norfolk Posts: 7 ![]() ![]() ![]() |
Hi rudy are these still going strong ? How long have you had them fitted ? Many thanks |
OS one went in 2023 and the NS one in 2024. Both still fine and to be fair, a good quality item. 2007 Range Rover Vogue 3.6 TDV8 |
Thank you , I will go with Britpart then , can’t justify genuine |
