![]() | Home > Technical (L405) > Panoramic sunroof stuck open |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Check the WM or handbook, usually you remove the centre roof console and you can wind it shut with the appropriate tool..
ross161 Member Since: 21 Feb 2017 Location: Birmingham Posts: 15 ![]() ![]() ![]() |
Thanks for the suggestion but already tried that. There is no manual override mentioned in the technical manual and not screw / hole on the motor. 2014 SDV8 Autobiography |
ss10 Member Since: 05 May 2025 Location: Reston, VA Posts: 39 ![]() ![]() ![]() |
L405? Your signature says you have a 2007.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441 ![]() ![]() |
From the WSM
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 99 ![]() ![]() ![]() |
Hi there - I had that issue after letting someone else drive my car... and for some reason a small piece of plastic had broken off the roof track surround and was caught in the rail in which the glass roof panel runs - worth a look!
Thanks guys will go and double check, I don't think there was anythign visible in the tracks but it's all under a rubber seal so trick to see, will poke something down there and see what I can see.
