Home > Technical (L405) > Panoramic sunroof stuck open
ross161
United Kingdom 2014 Range Rover Autobiography SDV8 Barolo Black
Hi folks
As above. Blind working fine but sunroof is stuck fully open since the wife came back yesterday. All fine until it starts raining....
Fuse is good, motor is good, reset procedure just results in some clicking. IID tool is showing B10F2-9A Sliding roof component failure, followed by B10F2-4B Sliding roof over temperature if you keep trying to close it.
Mechanism is trying but something on the track mechanism is catching / broken, it tries to move a few mm before stopping. Have read technical manual and I can't see any way to gain access to anything useful without removing headlining and possible the whole pan roof assembly.
Anyone experience simliar who can share some advice? I'm mechanically minded but really can't bring myself to remove headling or go any further. My local specialist has no appetite to start messing with it either, and I don't want to line the dealers pockets. Any recommendations for RR / pan roof experts (Staffs, UK).
Thanks you. 2014 SDV8 Autobiography
Post #721215 13th Jul 2025 11:48am
Check the WM or handbook, usually you remove the centre roof console and you can wind it shut with the appropriate tool..
Thumbs Up Pete
Post #721233 13th Jul 2025 4:49pm
ross161
Thanks for the suggestion but already tried that. There is no manual override mentioned in the technical manual and not screw / hole on the motor. 2014 SDV8 Autobiography
Post #721244 13th Jul 2025 8:18pm
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
L405? Your signature says you have a 2007.
Its a cable driven system. A pair of cables that push and pull from both sides. If there is no debris obstructing the movement of the panel (I'm assuming you have already checked) then it may be a broken or jammed cable. If one cable is working and the other is not then the panel may twist in place and jam when trying to operate. If that is the case then you may be able to assist the non moving side by hand and try to get it closed.
Trying to operate it using hex port on the motor may not work in this case anyway. That port is for when the motor dies and you need to close it.
Search the Internet for pictures. You'll get an idea on how the overall system works. Here's one: https://www.gentlemenofsalvage.co.uk/produ...13-to-2017
Post #721247 13th Jul 2025 9:32pm
Kot
From the WSM
Motor noise present but no mechanism movement
Cracked motor gear wheel, Remove and replace the roof opening panel motor. Check for
debris. 2018 SE SDV8 4.4 Byron Blue
Post #721251 14th Jul 2025 9:01am
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi there - I had that issue after letting someone else drive my car... and for some reason a small piece of plastic had broken off the roof track surround and was caught in the rail in which the glass roof panel runs - worth a look!
(Not sure what they did - they assured me that they had not poked anything out of the roof aperture, but had opened the roof, so the blame was laid squarely at their feet)
W. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #721255 14th Jul 2025 10:30am
ross161
Thanks guys will go and double check, I don't think there was anythign visible in the tracks but it's all under a rubber seal so trick to see, will poke something down there and see what I can see.
Hopefully signature is fixed, last time I posted I was in a L322! 2014 SDV8 Autobiography
Post #721256 14th Jul 2025 10:40am
