![]() | Home > Technical (L405) > Software upgrades in 2018 L405 |
| adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884
The youtube channel of PowerfulUK deals with replacing and upgrading infotainment and other modules. There are several configurable options in the car's system files. While accessing them isn't exactly easy or cheap, the most effective and widely recommended tool for Land Rover owners is the IIDTool from Gap Diagnostic. |
| Inigo Member Since: 15 Jan 2014 Location: Kent Posts: 60
I've previously used a gap IID to enable/add loads of options on previous Land Rovers, I'm struggling with the current one as it already had most of the options ticked but in the past I have added:
| myL405 Member Since: 15 Jul 2025 Location: Antwerp Posts: 10
Thanks for the feedback. Have both VXDiag VCX SE (i.c.w Pathfinder) and the 1st model IIDTool (registered to my RRS). Not sure about the support on my IIDTool. Will check this youtube channel mentioned. Will come back to this |
| Tomo676 Member Since: 07 Aug 2018 Location: Aberdare, South Wales. Posts: 69
My 2017 FFRR has a parking heater fitted, but I can't get it enabled to use as a option on the infotainment screen using GAP iid tool. Very frustrating. |
I have successfully enabled the following features with the incredible IIDTool:
On youtube I found some very usefull videos for the future but under the RR L405 I still did not found any video how to update firmware in the modules yet |
| Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 235
Not sure if this is of any help, I had a 2018 for a short while, i contacted the local main dealer who pushed an update for the vehicle through -
Thanks for your feedback. I'm not sure yet which versions I'm running, but I saw that the last formal service visit was 2021 at 22K kms. Would be interesting to know if updates are done via Topix or can Pathfinder also upgrade ? |
In the IIDTool 4 menu there is a submenu ECU info, where available updates are shown. In my case updates exist for: CHCM-Chassis Control Module - Update available (ECU Flash Supported) DSM-Driver Front Seat Module - Update available (ECU Flash Supported) PAM-Parking Assist Control Module - Update available (ECU Flash Supported) PSM-Passenger Front Seat Module - Update available (ECU Flash Supported) RCM-Restraints Control Module - Update available (ECU Flash Supported) RFA-Remote Function Actuator - Update available (ECU Flash Supported) SOD-Side Obstacle Detection Control Module - Update available (ECU Flash Supported) A few other updates are listed as available but flash is not supported. Maybe a discussion with Gap Diagnostic will help understand the module firmware update possibilities. |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1879
IMHO, I would only update to try to solve a problem, if everything is working fine, never update just for the sake of it and risk creating problems you might then struggle to fix. Same applies to all electronic stuff.
| Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 99
I work in the IT industry and when it comes to multiple units talking to each other in adverse conditions - such as a vehicle - I drum into the team - if it ain't broke, DON'T fix it! (caveat - if it is a CCF change to enable something that wasn't there before - I'm all in!)
You are absolutely right! While the car was under warranty, several firmware updates were performed and almost each time it took a very long time and there were problems, sometimes it was held overnight to retry the update the next day... |
Thanks for your help so far. It is always a journey with these cars... |
