| Evening folks. Another couple of jobs ticked off the list. First up, a gearbox service.
       |  |     | Click image to enlarge |  Bonus transfer case shot
       |  |     | Click image to enlarge |  Spied a leak whilst I was down there. Further investigation is required here, I have recent evidence of Oil cooler replacement so I should be able to rule that out.
       |  |     | Click image to enlarge |  New ZF pan.
       |  |     | Click image to enlarge |  Old pan indicating an April 2014 production date. The original filter at least!
       |  |     | Click image to enlarge |  I’d say it was fairly safe to assume that this is the original fluid, too. I did a full drain/fill sequence with gearchanges/increased idle speed in between to ensure the torque converter was full of fluid. I was able to drain approximately 3 litres of oil at a time. I actually did this 5 times and ended up with a much, much cleaner fluid.
 The only real way I could show the fluid colour was by shaking it like a maniac. I didn’t have paper or smaller vessels on hand, sadly.
 With the gearbox oil changed, I reset the adaptation values and went out for a drive. As expected, there was some weird behaviour initially, though this has now stopped after some miles and I’m pleased to report that it’s silky smooth. Particularly noticeable from cold. It used to hang onto second gear and was a little harsh engaging third. Not anymore!
 I did also change the front differential fluid, though I forgot to take any pictures.
 Next up was the rotten rear plate in the incorrect size…
       |  |     | Click image to enlarge |  Off, to reveal that someone with a not so delicate hand had been here before. Note the gouges in the paint where someone had used a tool. Applied tar & glue remover to clean up the sticky pad residue.
       |  |     | Click image to enlarge |  Hit it with the polisher to remove some of the damage. 3M Fast Cut Plus on an MF pad, followed by Menzerna 3800. It’s much better, though not perfect.
       |  |     | Click image to enlarge |  Much better! Fitted with a fresh dealer plate in the correct size.
 Finally, I took a look at the MAP sensor.
       |  |     | Click image to enlarge |  I’ve not seen one quite as nasty as this. I did check the live data to read the data from this sensor, and it seemed well, though I’m not sure how. There was a layer of oily gunk, over the top of some very hard carbon. I soaked it in brake cleaner and managed to get it a lot cleaner. No discernible difference in how it runs or drives though
       |  |     | Click image to enlarge |  After seeing the state of this, I can only imagine the state of the plenum & inlet manifold. Do people delete the EGR’s on these with success? Asking for a friend
