![]() | Home > My Range Rover > Road trip spares- 4.4 TDV8 |
Ajmngn Member Since: 25 May 2021 Location: Cambridgeshire Posts: 210 ![]() ![]() ![]() |
Decent high lift bottle jack to get wheel off the ground in the event you need to get it off or have a decent look underneath. I also carry a single jack stand for safety in that case. Yes, it’s a bit bulky and a pain to stow out of the way but worth its weight in gold if you need to do anything that involves lifting the car.
Hobo_Ash Member Since: 20 May 2025 Location: Essex Posts: 5 ![]() ![]() ![]() |
Thats great, thanks for all of that. Regarding the GAP IID is there any reason i should get a G4 instead of a G3 seeing as 2012 L322 is covered on both?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
Breakdown insurance.
Tow ropes and shackles are also a good shout just incase, ive never carried anything like that before so will get a set.
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 439 ![]() ![]() ![]() |
One spare intake´doughhnut´hose and a good multi-metre 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1053 ![]() ![]() |
I only went to Belgium for a few days. Iv been after a full size spare for ages but no luck.
Thats also a good shout, aiming to finally get a good look under the bonnet at the weekend so il also see what condition my current ones are in.
What year is your car? Just wondered if you went G3 or G4 on the Gap tool? |
very nice |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Don’t forget a tyre inflator 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Don't forget a decent bug remover and a bug removing towel to clean the windscreen every morning... |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 70 ![]() ![]() ![]() |
You can buy a G4, just buy a male/female dongle off Amazon and all you have to do is remove two pins for it to support the older LR’s. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883 ![]() ![]() ![]() |
The 4 way hose at the front of the engine is a known weak point causing coolant loss when it snaps.
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 299 ![]() ![]() ![]() |
A spare FSR. Get a used OE one from eBay, swap it with your working one and keep that in the glovebox. Simple enough to change them and you know you have a working spare and it’ll give you the confidence to swap it should you need to, on the road.
