![]() | Home > Technical (L322) > Battery drain - 2011 4.4 TDV8 Range Rover |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Interesting thread! I am currently unable to get into the car, the battery went flat, not a peep, and the key will not unlock, as the key is not contacting the internal key barrel indents. So, how do you get in? The only way I can think of is to try and get power onto the starter motor, somehow, and get enough power to unlock using the smart key. It must be Land Rover's answer to the Smart Key cloning. I read on another forum, someone sawing a rear lock striker plate in half. How?, no room. Another said there is a pull cord on the top tailgate, under the trim. It is inside the car, so it has to be open, one suspects. Glass-Cutter is another option. Any ideas chaps? |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 301 ![]() ![]() |
I had a similar issue and ended up cutting the OSF door striker (handle cable had snapped so it wouldn't open but I could enter using the key on the NSF door). Made a bit of a mess though, mainly because I/we didn't cover the blade properly on the sides and it rubbed the paint off the door shut.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1243 ![]() ![]() ![]() |
These cars are so sensitive with batteries I have resorted to installing a BM6/BM2 battery monitor on all my cars. Relatively cheap (about £10) if you order on aliexpress etc, these fit to the battery and you can monitor the charge, charging rate and start up power fluctuations over time on your phone via bluetooth.
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299 ![]() ![]() ![]() |
Have you got a tow bar and socket, I had this problem and bodged up some connectors and charged it through the tow socket enough to get the locks working. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1010 ![]() ![]() ![]() |
that's what I have done, using a CTEK MXS 5, and only plug it in when not using her for a week or so
