Home > Maintenance & Mods (L405) > 2018 SV clunk
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Next mission is find the right oil for it and change it the weekend
Post #721763 23rd Jul 2025 11:34am
M3bobby
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
M3bobby wrote:
I have a 68 plate SV, 48,000 miles, had my rear differential and transfer case flushed a few months ago and I think it’s worse. Im now convinced the wrong oil has been used as there is a specific oil to use on the edif and not the type used on the L405 open diff. I’ve purchased the correct oil from LR and will do it myself this weekend and see if there’s an improvement. I’ve read lots of issues on the ediff and although most display the same symptoms, some are slightly odd, but is still down to the incorrect grade of oil.
So I changed mine today for genuine LR specified oil and it appears to have cured it. Annoyingly, my specialist Indy supposedly changed the oil on the 19th March, 3800 miles ago. As I dropped the oil I could see it was filthy, what do you think?
Post #721921 26th Jul 2025 7:43pm
zenman63
Not good at all, probably the wrong oil.
I will also do mine now, what oil did you use?
Part number, 2L I guess
Post #721925 26th Jul 2025 8:07pm
M3bobby
This is what I bought, the part numbers were from LR topix.
According to the invoice from my independent, they used the correct oil. But I don’t see how it’s got that dirty in 4 months and less than 4000 miles.
Post #721926 26th Jul 2025 8:37pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
That’s great to hear, keep us posted Thumbs Up 2019 SV AB Dynamic Scafel Grey
Post #721930 27th Jul 2025 8:16am
X1jimmie
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
Did you get 2L out? Perhaps they didn’t fill it enough. Although you’d hope they know what they’re doing Previously owned: Range Rover L322 2007 TDv8 Vogue SE in Santorini Black
Post #722044 29th Jul 2025 7:02pm
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
I have exactly the same problem. I've been told all sorts - fuel sloshing about in the tank, CV joints, bushes, brake disks. However I also believe it is either the diff or transfer box. I will get them both flushed and let's see if that sorts it out. 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #722079 30th Jul 2025 10:11am
