![]() | Home > Maintenance & Mods (L405) > 2018 SV clunk |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3255 ![]() ![]() ![]() |
fuel slopping around in the tank ? |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 237 ![]() ![]() ![]() |
No it’s something moving.
chicb Member Since: 28 Nov 2019 Location: Dundee Posts: 140 ![]() ![]() ![]() |
Possibly the transfer box needing a double flush. Lots of posts on that here. Clonking when taking off, like something in the boot. Once moving it vanishes. I had that took it into Mikey couple of weeks back, double flush, recalibrate something, noise gone. Early days but seems positive. Used to drive me nuts |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
Mine does have a clunk too . Had in to MD who advised all 4 ARC bushes were shot and were the first port of call. Replaced all 4, made zero difference. Weird thing is , my first 405 (2013) did something very similar, 3 clunks when pulling of from a standstill, and sometimes on a rolling take off from a roundabout. It's way more pronounced with the newer one though, and just heard it when reversing in a parking space which is a 1st.
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 51 ![]() ![]() ![]() |
Hi
Hmm thanks for that.
RR YORKS - sent you a pm . |
X1jimmie Member Since: 08 Jan 2019 Location: Hertfordshire Posts: 8 ![]() ![]() ![]() |
I don’t have an answer for you but I think I have the same issue. I often hear it when accelerating onto a roundabout. Especially if I’ve been rolling up to it Previously owned: Range Rover L322 2007 TDv8 Vogue SE in Santorini Black |
It sounds like a ball rolling in the boot, almost seems the diff is slipping.
M3bobby Member Since: 28 May 2019 Location: Lincolnshire Posts: 17 ![]() ![]() ![]() |
I have a 68 plate SV, 48,000 miles, had my rear differential and transfer case flushed a few months ago and I think it’s worse. Im now convinced the wrong oil has been used as there is a specific oil to use on the edif and not the type used on the L405 open diff. I’ve purchased the correct oil from LR and will do it myself this weekend and see if there’s an improvement. I’ve read lots of issues on the ediff and although most display the same symptoms, some are slightly odd, but is still down to the incorrect grade of oil. |
If it is the diff could this be tested by changing the terrain response mode? I.e. put it in sand mode and see if the noise is more/less apparent Previously owned: Range Rover L322 2007 TDv8 Vogue SE in Santorini Black |
Never thought about that, mine has full MD history so has allegedly had all fluids changed to spec, but has never had a gearbox flush though.
I don’t think sand mode will work as it’s more random.
100% 3 thumps from mine 2019 SV AB Dynamic Scafel Grey |
