Home > Maintenance & Mods (L405) > steering column gaiter
Page 4 of 4 <1234
dez
United Kingdom 2017 Range Rover Vogue SDV6 Santorini Black
Hi All, I’m new to range rovers and this site 😊
I have recently purchased Range Rover vogue 2017 and the steering column gaiter is split and need replacing. Can someone clarify a few things for me please.
1) Is DA3689 – the correct gaiter for my car?
2) Is LR033647 or LR033648 – the correct complete unit?
3) Is 1x LR033655 & 1x QYG500090 – the correct steering column bolts required if I replace 1) or 2) ?
I understand this can be done easily, do you need to do any steering or wheel alignment adjustments afterwards?
Thanks in advance for your help.
Dez
Post #703172 27th Oct 2024 12:53pm
no alignment adjustments needed and it is a 10 minute job, the shaft pushes back up inside the steering column to give you clearance to fit the new bit ... ... - .- -.
Post #703186 27th Oct 2024 3:30pm
dez
Hi Stan, thanks for a quick response. I’ll search for a complete unit, hopefully I should be able to find one on eBay/internet.
Dez
Post #703201 27th Oct 2024 4:45pm
Gremlin500
Hi All,
Revisting this thread again because, guess what? Yup!
Split again! Censored
Fortunately, this time I had a complete refurbished one “in stock” complete with new bolts, so had it sorted in about 15mins.
The rubber bellows are now available on AE cheaply, and IMHO are the same quality as the JLR ones, (not that that says a lot). The hard bit is getting the new rubber over the joint, once you have cut the old bellows off. I made a tool from the cut-off tip of a CV Joint heavy plastic cone, (the kind you use to replace CVJ bellows) and with some silicone grease, was with some effort, able to get the boot over cone and joint, then remove the cone through the hole at the opposite end. This is NOT easy and requires persistence, but saves a fortune. Very Happy
After installing the “new” joint back on the car, I promptly cleaned & fitted a new boot (also in stock Laughing ) to the original one, ready for 2027 Rolling with laughter Rolling with laughter Rolling with laughter
If anyone’s interested, I can post a pic & dimensions of the “tool” you need to do it.
First time cost about £50, then £20 each time. V6 Vogue - “Less is More” - less to go wrong!
Post #722591 9th Aug 2025 3:18pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
checked mine and its got a split in it so going to have mine to do ............have found this (DA3689)
so think im going to use this Thumbs Up
Post #722634 10th Aug 2025 2:22pm
Gremlin500
Hi Will, good luck, and be warned:
It’s a total b*tch to get the new rubber over the joint, as it has to stretch the hole from ca. 25mm diameter to over 50mm,, this is almost impossible without using a suitable lubricated cone, or you will tear the rubber.
The ones on eBay are twice the price (£40) as AE (£20) however identical.
The difference seems to be the sellers profit margin. V6 Vogue - “Less is More” - less to go wrong!
Post #722641 10th Aug 2025 3:47pm
will308f
Thumbs Up yea lots of silican lub i’ve got a cone of sorts so fingers crossed and af are the same price as everywhere else
Post #722643 10th Aug 2025 3:54pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Love this place, mine is also split, it looks a mission to get at but at least you can see it.
I will try my warranty!
Post #722940 16th Aug 2025 3:05pm
Gremlin500
Wow, V8! -it’s much easier to do in off-road height (to straighten the joint) standing on a small box or whatever on the V6. The hardest part is then replacing the rubber bit, and of course not dropping the bolts 😁. Always use new screws with encapsulated locking compound, -it is the steering after all. V6 Vogue - “Less is More” - less to go wrong!
Post #722942 16th Aug 2025 3:45pm
nike_bytom
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Just replaced mine too with a cheap one off eBay—no issues, looks like good quality rubber.
https://www.ebay.co.uk/itm/356239698898
 L405 4.4 Vogue
L538 2.2 Prestige
Pozdrawiam
Rafal
Post #723245 22nd Aug 2025 9:49am
zenman63
Looks like you have plenty of space there.
Boot fit easy enough?
Post #723251 22nd Aug 2025 10:18am
nike_bytom
Haha, yes, the engine is out so it was very easy to replace the boot. And no, I didn’t remove the engine just to replace the boot, haha. At first, I struggled to fit the boot over the joint, but after applying plenty of engine oil to the rubber boot, it became much easier. I mounted the joint in a vice first, then stretched the hole using both hands and fingers to fit it over the joint. L405 4.4 Vogue
L538 2.2 Prestige
Pozdrawiam
Rafal
Post #723253 22nd Aug 2025 10:22am
Page 4 of 4 <1234
