![]() | Home > Maintenance & Mods (L405) > steering column gaiter |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
no alignment adjustments needed and it is a 10 minute job, the shaft pushes back up inside the steering column to give you clearance to fit the new bit ... ... - .- -.
dez Member Since: 27 Oct 2024 Location: London Posts: 2 ![]() ![]() ![]() |
Hi Stan, thanks for a quick response. I’ll search for a complete unit, hopefully I should be able to find one on eBay/internet.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1854 ![]() ![]() ![]() |
Hi All,
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 602 ![]() ![]() ![]() |
checked mine and its got a split in it so going to have mine to do ............have found this (DA3689)
Hi Will, good luck, and be warned:
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 256 ![]() ![]() ![]() |
Love this place, mine is also split, it looks a mission to get at but at least you can see it.
Wow, V8! -it’s much easier to do in off-road height (to straighten the joint) standing on a small box or whatever on the V6. The hardest part is then replacing the rubber bit, and of course not dropping the bolts 😁. Always use new screws with encapsulated locking compound, -it is the steering after all. V6 Vogue - “Less is More” - less to go wrong! |
nike_bytom Member Since: 29 Mar 2025 Location: Thrapston Posts: 26 ![]() ![]() ![]() |
Just replaced mine too with a cheap one off eBay—no issues, looks like good quality rubber.
Looks like you have plenty of space there.
Haha, yes, the engine is out so it was very easy to replace the boot. And no, I didn’t remove the engine just to replace the boot, haha. At first, I struggled to fit the boot over the joint, but after applying plenty of engine oil to the rubber boot, it became much easier. I mounted the joint in a vice first, then stretched the hole using both hands and fingers to fit it over the joint. L405 4.4 Vogue
