![]() | Home > Technical (L405) > Front Windscreen / Windshield Interior Air Temperature |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8751 ![]() ![]() ![]() |
The black casing behind the mirror give this fault, and similar, if it's faulty...
heretolearn Member Since: 27 Oct 2024 Location: Kuala Lumpur Posts: 53 ![]() ![]() ![]() |
Thanks for the reply. Yeah I'm trying to figure out the sensor placement and which sensors to order just in case mine is faulty. A sensor read of - 2048 celcius can't be right on an average 37C weather lol.
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 144 ![]() ![]() ![]() |
The windscreen temperature sensor is a single unit with three sensors: interior temperature; windscreen temperature; humidity. It's part number LR058011. It's easy to replace. |
Thank you for the info. By any chance you have the instructions on how to remove the plastic cover? |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1817 ![]() ![]() ![]() |
Not strictly the same thing I realise, but some of the nformation in this thread may be helpful:
It "just" pulls off, though on mine it was quite stiff. |
Awesome! I'll try open it up on the weekend to check if its plugged properly. Worse case I'll order a new sensor. Fantastic help guys. |
