Home > Technical (L405) > Front Windscreen / Windshield Interior Air Temperature
heretolearn
Malaysia 2019 Range Rover Vogue SE SDV8 Loire Blue
Hi All,
I was having a B13F1-92- Auxiliary Distribution Flap Actuator Motor - performance or incorrect operation (2Cool error for a while now and did a data stream to narrow down any inconsistencies with the HVAC system. To my surprise I am probably having an open circuit on the windscreen interior air temperature sensor as it is reading - 2048Celcius.
Now I'm trying to narrow down the location of this sensor. Is it located at the black casing behind rear view mirror? Or is it hidden inside the dashboard, windscreen pointed vent?
Appreciate any help on this.
Post #722952 16th Aug 2025 6:05pm
The black casing behind the mirror give this fault, and similar, if it's faulty...
B13C2-49 (6C) Windshield misting sensor - System internal failure - internal electronic failure
Can't help directly with your issue though.... Pete
-Click here for Thread-
Post #722977 17th Aug 2025 9:51am
heretolearn
Thanks for the reply. Yeah I'm trying to figure out the sensor placement and which sensors to order just in case mine is faulty. A sensor read of - 2048 celcius can't be right on an average 37C weather lol.
KY
Post #723012 17th Aug 2025 5:15pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
The windscreen temperature sensor is a single unit with three sensors: interior temperature; windscreen temperature; humidity. It's part number LR058011. It's easy to replace.
Post #723059 18th Aug 2025 9:49pm
heretolearn
Thank you for the info. By any chance you have the instructions on how to remove the plastic cover?
Post #723066 19th Aug 2025 5:56am
Gremlin500
Not strictly the same thing I realise, but some of the nformation in this thread may be helpful:
https://www.fullfatrr.com/forum/topic71770.html V6 Vogue - “Less is More” - less to go wrong!
Post #723088 19th Aug 2025 1:01pm
hmallett
It "just" pulls off, though on mine it was quite stiff.
Post #723110 19th Aug 2025 9:44pm
heretolearn
Awesome! I'll try open it up on the weekend to check if its plugged properly. Worse case I'll order a new sensor. Fantastic help guys.
Post #723141 20th Aug 2025 6:11pm
