![]() | Home > Technical (L322) > 2011 fuel gauge |
physio Member Since: 31 Aug 2020 Location: Essex Posts: 6 ![]() ![]() ![]() |
Have the same issue with fuel guage showing empty. Has anyone any pictures of how to remove the clamps / springs from inside the tank? Just in case I have to remove the internal stuff. |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102 ![]() ![]() ![]() |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Physio
Thats great. Thanks to you both. One more question. Whats the best connectors to use once the old plugs are removed? And do they have to be 'diesel' proof? |
IIRC I simply used in line crimps suitable for the cable size and they weren't
Thanks Richard. Will do. Will let you know how i got on. |
Good luck |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Thanks for the great posts people. Dealer i brought the car from had not heard of this fix!! so they are happy as only cost them the labor to apply the fix.
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 157 ![]() ![]() ![]() |
I too seem to have this problem, suddenly fuel gauge showing zero and not knowing of this sender fault I filled her up !
Old-un, most of the sometimes three, four, or five connectors are below fuel level, it's best to replace all or you may end up doing it again.
Finally bit the bullet and arranged for an indy to sort it for me. Garage was 11 miles away and I set off with my wifey following, all done in limp mode and as expected the vehicle stopped every 500 yards but restarted every time 'till I eventually hopped to my destination ( just keep away from motorways ! )
NJPovey Member Since: 30 Dec 2020 Location: Sussex Posts: 11 ![]() ![]() |
Last year the in tank fuel pump on our old TD6 packed up. I wasn't wanting to spend lots of money on the 150,000 miles workhorse so bought a cheap pump unit complete with the fuel level senders.
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 154 ![]() ![]() ![]() |
I have just done mine.
Twin-RR Member Since: 30 Jul 2025 Location: Cape Town Posts: 5 ![]() ![]() |
I have a 4.4 TDV8 and encountered the same problem as Richard-RJFF and Bushy30.
