Home > Maintenance & Mods (L405) > Check oil level on MY 17 car
Page 3 of 3 <123
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I would happily pay someone to put a dipstick on to my engine. I do not understand why we need to have an electronic system. Even my mini has the same electronic system to check the oil level. I mean, how hard is it to flip the bonnet, retrieve dipstick, wipe, reinsert, and read. If you can’t manage that, you shouldn’t be allowed to drive a car. Grrrr rant over
Post #564932 18th Aug 2020 7:17pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi zebedee. Not sure if it’s a typo or just a guess at your oil quantity 7.2 litres. It’s actually 9.5 litres on the 4.4. Just done mine last weekend Thumbs Up
Post #564966 19th Aug 2020 7:37am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Yes, you're right. Checked the required quantity and put that in. What came out was the same so I don't believe I'm using a lot of oil. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #564972 19th Aug 2020 8:56am
Gremlin500
……….. V6 Vogue - “Less is More” - less to go wrong!
Post #628485 12th Apr 2022 8:01pm
Two Tone
United Kingdom 2014 Range Rover Vogue 4.4 V8 Zambezi Silver
I note that there are other threads on this subject :
https://www.fullfatrr.com/forum/topic56693.html
https://www.fullfatrr.com/forum/maintenance-mods-l405-vf42.html
Home > Maintenance & Mods (L405) > Engine Oil Level - Not Available [4.4 SDV8]
Dealing with the same subject and with very valuable advice from Zebedee on how to make a DIY Dispstik using a base guitar string.
I have copied his system using some plastic strimmer cable and am glad to report that the SDV8 L405 that I recently bought with the dreaded ‘Not available’ fault is bang on the 73cm full mark he suggests.
A couple of mods: I have cable ties attached to the stopper that fits on the top of the suction tube so as not to lose it is I forget to put it back on:
And I have put my DIY dipstick into a flip lock bag along with some paper towel, to stow in the glovebox:
However, I still think it would not be difficult to make a proper Dipstick and consulted my local Indy 4x4 specialist Max, this morning with my ideas. He also knew of the base guitars string idea for the SDV8 but knows that it wont work for the SDV6 versions.
Having found and joined fullfatrr.com last evening, I drew some sketches and went to talk about them to him this morning.
However, since starting to look for the fittings online, I have found and even more suitable one to replace both the M14 male-male adapter and the ‘T’ peice:
I’d love to know everybody’s opinions, because this really doesn’t look like a difficult fix.
Max and I are going to attempt the real thing on my RR Vogue SDV8, when it next needs an oil change.
If it works, we might even assemble and offer kits to other RR users.
Post #723051 18th Aug 2025 7:10pm
Page 3 of 3 <123
