Home > Maintenance & Mods (L405) > Sunroof drain maintenance
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
So today I thought it was overdue time to check the sunroof drains on my 2015 L405. I have seen some horror stories of these rusting out and then causing huge damage to the interior, so I was more than a little nervous taking off the trim panels to expose the drains.
Luckily, although there was some crud, the drains were not blocked and cleaning the area down the water ran away freely. I poured about 2 litres of water into the channels to flush them out and the water all drained easily.
On drying it all off (I used my car blower/dryer) I found only the slightest trace of rust around the drains. I used Kurust to treat this minor surface rust and then Lanoguard to seal and coat the drain tube area.
I feel lucky that I didn’t discover a horror story today, but would encourage others to check/clean/wax the drains on their L405. It’s an easy job to pop the trim panels off and check.
Post #723363 24th Aug 2025 1:30pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Also the sleeve insert could be of help:
https://www.fullfatrr.com/forum/topic74149.html
Post #723364 24th Aug 2025 1:37pm
Bardley
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
Worth noting that you can see the drain holes without risking the trim removal. Use a ladder, and look back along the channel when the roof is open.
Use adapted tools to clean out any muddy paste.
Using strimmer line, or the tool for the job with the pipe brush, it's easy enough.
Flush through with a Milton solution and watch for the fluid exit near rear mudflap. L405 2014 FFRR Autobiography
Corris Grey
Previously 2011 D4 SDV6 HSE Santorini
Post #723387 25th Aug 2025 8:18am
Alex1976
I think for future maintenance that is the way to go, but I wanted to get a proper look at them (and I was expecting to have to do some remedial work to them) this time as I had never inspected/cleaned them before.
Post #723393 25th Aug 2025 10:43am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Any advice for trim removal please?
Post #723420 25th Aug 2025 4:34pm
adara
Open the sunroof and starting from the front of the car, grab the trim from the inside and pull, there are four clips in total.
Post #723422 25th Aug 2025 4:50pm
Alex1976
These are the clips that hold on the aluminium trim rail
The trim piece has profiled channels that simply snap on/off.
Post #723425 25th Aug 2025 5:18pm
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
Should the water drain from rear mudflaps for both passenger and driver side?
On my car I poured some water on driver side and that drains from rear mudflaps are BUT the passenger side start drain from top of windscreen and then down to wipers and eventually to behind front wheel?? I have not water leak inside that I know of!
Is this right?
Post #723447 25th Aug 2025 11:37pm
Alex1976
Both sides exit at the top of the rear wheel arches. If you have water exiting to the front then this suggests that the drain is blocked.
See below - drains are marked as 4 and 6
Post #723449 26th Aug 2025 12:06am
There's a good video to watch - and the same guy has a second one showing where the drains exit the vehicle.
It's on this thread - https://www.fullfatrr.com/forum/topic74149.html
Post #723458 26th Aug 2025 9:26am
Maher2023
Thanks Alex, I checked the nearside drain with help of torch…and as expected it was rusted/blocked. I used a flexible drain cleaner and pushed on the rust and it broke away and water started to drain near the rear mudflap straight away.
Poured more water and now it drains straight away in the rear arch.
Rust might be thin layer and probably recently start to build…I’ll check on monthly basis now.
Thanks for your help. 🙏
Post #723474 26th Aug 2025 5:11pm
