![]() | Home > Maintenance & Mods (L405) > Sunroof drain maintenance |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 879 ![]() ![]() ![]() |
Also the sleeve insert could be of help:
Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 30 ![]() ![]() ![]() |
Worth noting that you can see the drain holes without risking the trim removal. Use a ladder, and look back along the channel when the roof is open.
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 187 ![]() ![]() ![]() |
I think for future maintenance that is the way to go, but I wanted to get a proper look at them (and I was expecting to have to do some remedial work to them) this time as I had never inspected/cleaned them before. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1513 ![]() ![]() ![]() |
Any advice for trim removal please? |
Open the sunroof and starting from the front of the car, grab the trim from the inside and pull, there are four clips in total. |
These are the clips that hold on the aluminium trim rail
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 65 ![]() ![]() ![]() |
Should the water drain from rear mudflaps for both passenger and driver side? On my car I poured some water on driver side and that drains from rear mudflaps are BUT the passenger side start drain from top of windscreen and then down to wipers and eventually to behind front wheel?? I have not water leak inside that I know of! Is this right? |
Both sides exit at the top of the rear wheel arches. If you have water exiting to the front then this suggests that the drain is blocked.
