Home > Maintenance & Mods (L322) > Can't open door with key, battery flat, what can I do?
Rjhoy02
United Kingdom 2008 Range Rover Vogue SE TDV8 Barolo Black
Hi, the alternator has packed up on our 3.6 v8 vogue se, and I cant get into the car to open the bonnet. When I try the key it feels like the mechanism isn't connected to anything. The remotes aren't doing anything either.
Is there a way to get at the cable to release the bonnet?
Post #723661 30th Aug 2025 5:26pm
If the alternator has fully gone - as in the diodes failed, then you may have to disconnect it from underneath & then put some charge into the now disconnected cable.
There may be something on one of these these threads - https://www.fullfatrr.com/forum/search.php...rch_time=0
Post #723670 30th Aug 2025 8:27pm
Rjhoy02
Thanks I'll get reading Thumbs Up
Post #723689 31st Aug 2025 1:02am
Rjhoy02
Success! I connected a smart charger to the starter terminal and a good ( Exclamation ) Earth point, no joy it just came up error. This morning I dug out an old charger and it gave enough power to unlock the doors with the remote.
I've now got the battery on charge and will tackle the door lock when it stops raining Exclamation
Thanks for your help Thumbs Up
Post #723701 31st Aug 2025 12:35pm
Glad it worked out for you Thumbs Up
Post #723705 31st Aug 2025 3:02pm
