Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322!
Page 31 of 31 <123 ... 293031
JayGee
Engine off the damping should be at max. Back end will feel very unstable when cornering. Mine were ‘OK’ at 170k miles and when pushing down on them off the car were still pretty stiff. 2012 TDV8 Vogue (L322)
Post #723764 1st Sep 2025 5:50pm
Vogue4.4tdv8
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
My cars pushing 182k
Had a L405 sdv8 before this but i love my l322
Will try and source some rear shocks
Some on eBay but don't know if they will last long
Anyone know part numbers ?
Once replaced do they need calibration or should self learn? Not sure if that garage has the correct diagnostic tool for it
Post #723769 1st Sep 2025 6:28pm
JayGee
Be careful with cheap options. There have been examples of fakes with no CVD internals and a resistor to fool the ECU. Island4x4 seem to be the best place for OE ( Bilstein) 2012 TDV8 Vogue (L322)
Post #723770 1st Sep 2025 7:09pm
Vogue4.4tdv8
Seen these on eBay
Item number:
eBay Item No. 376480739637
Post #723771 1st Sep 2025 7:18pm
Vogue4.4tdv8
Can someone also clarify what the engine off, shock bouncing test tells us
Why are the shocks solid with engine off ?
I thought they should firm up when current is applied...
Post #723784 1st Sep 2025 9:12pm
JayGee
Vogue4.4tdv8 wrote:
Seen these on eBay
Item number:
Almost a certainty these are 'fake' CVD at that price.
Can't go wrong with these - https://www.island-4x4.co.uk/rear-shock-ab...39872.html 2012 TDV8 Vogue (L322)
Post #723800 2nd Sep 2025 8:18am
JayGee
Internal valving is closed when powered off. 2012 TDV8 Vogue (L322)
Post #723801 2nd Sep 2025 8:19am
Vogue4.4tdv8
Hi Jay
So basically the valves are broken in the rear shocks for them to be doing that?
£100 for a pair seems too good to be true!
Did see the ones on island 4x4, but pricey! Just want to be certain it is the rear shocks busted
I read on a post that cvd calibration is necessary if the ECU is replaced
Post #723802 2nd Sep 2025 9:42am
