Home > Maintenance & Mods (L405) > Just been Bodsy'd
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
CerebralThunder wrote:
Thanks for the replies.
I'm genuinely interested in Bodsy's process, as I recently had engine oil and filter replaced, both diff oils, transfer box fluid and gearbox megaflushed, but the car is driving worse than before the work. It seems to be hunting for gears and changing between them quite harshly. As you know, it's a very expensive process.
They have very kindly agreed for me to take it back to them so they can have a look into it, but I wondered if there was a bodsy secret ingredient?
Do you know if the gearbox adaptations were reset properly with an IID tool or similar after the flush? As far as I am aware, they should have been FFRR SDV8 Autobiography
Post #723996 5th Sep 2025 11:23am
CerebralThunder
I'm unsure in regards to software adaptions or the procedure they took to change the oil and flush. I'm arranging the car to go back so hopefully they can sort.
I'll let you know how I get on. 2021 L405 Range Rover 'Fifty' D350
Post #724001 5th Sep 2025 12:13pm
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
IIRC Ian doesn't recommend doing the adaptations - he didn't on my L322 or my L405.1
I wouldn't sweat about it unless you are trying to diagnose some shifting issues
Post #724002 5th Sep 2025 12:18pm
