Home > Technical (L405) > 4.4 SDV8 - Constant DPF Regen/Pressure Sensor Issue
Hallza
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Hello,
Wonder if anyone could help shed some light on a current issue with my L405.
Virtually every journey it try's to regenerate the DPF to the point I'm only getting 2500 miles per oil change!
No warnings on the dash, code read with the IID tool - no faults present.
Live data shows the DPF pressure sensor at 1010 mbar at idle (Should be 10/20 mbar at idle)
DPF is clean/not blocked and new genuine LR sensor fitted.
Current soot level less than 2g.
There is a TB from Land Rover that expains the issues perfectly - LTB00617 - Software update should have overcome but not the case.
Has anyone had the same issue and resolved or any suggestions?
Many thanks,
Post #721202 12th Jul 2025 10:31pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Have you checked the DPF pressure sensor reading with ignition on, engine off, as I think on the 2014 MY it adds barometric pressure based on altitude into the given value.
This changed to a more sensible reading without the barometric pressure on the 2016 MY, confused me a bit when comparing my 2014 L494 with my 2016 L405 and wondering why the readings were so different!
Have you done a smoke test, that would be my next port of call?
I get up to 750 miles between regens with optimal conditions, a bad day maybe 250! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #721204 12th Jul 2025 11:29pm
Hallza
Thanks for the tip,
Tried with ign off and no change in value.
Smoke test carried out - did highlight a leaking throttle body gasket and intake coupling - both now replaced with genuine parts.
I've just carried out the Pressure Sensor Calibration sequence, idle has reduced slightly, voltage is 0.52v, pressure reading 1000 mbar at idle.
Post #721222 13th Jul 2025 2:10pm
4RRS
Pressure sensor reading is valid then if same reading with ignition off as barometric pressure at seal level is 1013.
Air leaks will certainly affect regen frequency, run it and see how it goes. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #721224 13th Jul 2025 2:16pm
Kot
Barometric pressure changes all the time depends on the weather. Currently we are in High pressure zone in most of UK but when cooler front comes in its Low pressure. Thats why pilots when ready to land/take off, they get the weather from the tower and adjust their altimeters accordingly. 2018 SE SDV8 4.4 Byron Blue
Post #721235 13th Jul 2025 4:57pm
Kot
Re: 4.4 SDV8 - Constant DPF Regen/Pressure Sensor Issue
Hallza wrote:
Hello,
Many thanks,
JLR would say its your driving style.
Do you do mainly short journeys? probably a few interrupted Active Regens. What is the distance between AR?
Just drive the car, no alarms no DTC's its working as it should.
The software update? was it to increase the alarm level from 7% fuel dilution in oil to 10%? That was done to reduce the amount of complaints to JLR! Not a good idea in my view.
I usually get the alert on the Incontrol app to service vehicle (change oil & filter) between 2.5 & 3k
miles so you are not alone. 2018 SE SDV8 4.4 Byron Blue
Post #721236 13th Jul 2025 5:07pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
I fitted a genuine DP sensor in the ongoing quest to get more miles between regens. The original sensor readings were spikey and checking with a DP digital meter they were more or less where they should be but with spikes. I checked at different revs but not under load. My theory was that the spikes were giving a high DP reading and triggering regens prematurely.
The new sensor readings are a lot cleaner but it doesn't seem to have made a huge difference. I get 11miles per gram of soot and a regen every 160 to 200 miles depending on the type of journeys.
As advised above i'm trying to get into the mindset of letting it do it's own thing and not worrying about it until a light comes on.........but it's hard to resist having a wee peek Wink
Post #721289 14th Jul 2025 8:06pm
Hallza
Thank you everyone who replied, all seems to be working as it should other than multipul regens so putting it down to driving style/30 mile round trip journey a day.
Best thing is to keep on top of frequent oil changes!
Post #724367 11th Sep 2025 8:09pm
Kot
Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #724371 11th Sep 2025 8:52pm
Dolphinboy
Check your internal engine temp. These engines run very cool in any case and my L322 4.4TDV8 (same engine) had a cracked thermostat housing which meant the engine ran extra cold and could never get up to high enough temp to complete a full regen (Had 3700 regen attempts over time!) so it kept trying to regen all the time.
Replaced the thermo housing and solved all issues. was only discovered by my LR indie specialist who used old school mechanic nous to work out why it was happening.
Post #724379 11th Sep 2025 11:22pm
Hallza
Thank you Thumbs Up
Post #724385 12th Sep 2025 8:34am
linus
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
I have a 2016 L405, and my oil change has also just come up again after 3000 miles.
It does an active regen approximately every 100 miles. The last oil change it had only done 3500 miles, although the specialist didn't think there was any evidence of oil dilution. I am going to get the oil analysed this time around to be certain.
Normally, my soot levels are at 20g when it regens and then drop to 3g.
I would hope to get at least 6000 between services, so this seems extreme.
Dolphin, what temperatures was it reading before you changed the thermostat housing? Mine normally runs around the 250 -300 degree mark until it actively regens.
Post #724407 12th Sep 2025 3:52pm
Dolphinboy
@Linus
Sorry I don't know the actual temps but my LR specialist put a probe in and ran the engine under heavy load, uphill and at high revs and it was below the normal operating temp.
He concluded that something was keeping the temps down and saw the crack in the Therm housing (damaged by a previous LR dealer when replacing the inlet manifold.)
Post #724414 12th Sep 2025 6:04pm
linus
Ok thanks, it was more for interest.
I think at the moment I am doing a lot of shorter low speed trips, typically 10-20 miles, often under 70 mph, so it’s probably just the way I am driving it.
Post #724420 12th Sep 2025 6:47pm
