Home > My Range Rover > Project Fatty Onroader 5.0 Supercharged
Page 17 of 17 <123 ... 151617
dhallworth
I'd second that, they're woeful!
Post #693665 30th May 2024 9:39pm
Driyage
Yeah I might have to replace them with the standard ones, I’ll see how I fare with these…
Stay tuned for the next update of putting the normal ones back on 😄
Post #693676 31st May 2024 9:14am
Driyage
Finally managed to book some ramp time on Tuesday for a service and a proper inspection.
Post #693961 6th Jun 2024 11:08am
toronnoRR
Canada
Haylands wrote:
I can't take any credit for the latest mod, the idea has been stolen from our very own Cam Tech Craig but as he's away in Italy thrashing the new Ferrari I thought I'd do it before he returns...
Can't understand why they didn't do this anyway... has anyone ever said "I have enough cup holders....!!!"
This is not plug and play, the cover and the inner dash need modification...
Track down a 2005-2012 LHD left dash end with the light switch hole...
I found a wood finish one for less than £25 delivered from the States... piano black ones were a silly price...
Drop it off at your local spray shop and £20 later it's looking good...
Take off the old one, then work out and mark up a section that needs to be cut off to miss the glove box, also cut a section out of the dash, nothing essential just some plastic webbing...
Cut off pieces...
Then fit the new cup holder, I got this one on eBay as NOS, it was £100 they retail from the dealer at around £140...
Then refit the trim and buy yourself a drink...
Much better... Thumbs Up
A lot cheaper if you can find a nice condition early cup holder but they do tend to wear out quick...
Hi, Hayland,
Do you know if this mod can work for North American LHD vehicles?
Post #693998 6th Jun 2024 7:29pm
I don't see why not, just get the panel for a RHD and modify it, you can try without any modification to the car so you will find out if it works before you go "too" far.... Just buy the panel and see if it fits before spending big bucks on the cupholder itself... Thumbs Up Pete
-Click here for Thread-
Post #694115 9th Jun 2024 9:47am
Driyage
Time for an update, had the Fatty serviced and checked out just before going on holiday.
All good apart from a small leak from the PS pump…
* All filters replaced with Genuine LR parts
* Oil change
* Plugs looked to be great condition so not replaced
* Wipers replaced with Bosch 808
Post #695175 28th Jun 2024 8:05am
Driyage
I might be looking at adding a CarPlay screen to replace the top centre dash vent (as someone else has done)
Can’t justify ~ £600 for the UAD solution as that’s the only one that seems to work properly without blurry screens etc
Should be completely reversible
Post #695176 28th Jun 2024 8:09am
Driyage
Another update,
Been pretty reliable so far so apologies for the lack of excitement!
Big service today:
* All fluids changed (Diffs, transfer case etc)
* Gearbox oil changed with filter and pan with the ZF lifeguard kit
* All rear and partial front brake pipes replaced ( along with brake fluid)
* Engine oil changed (with filters)
* All plugs changed
* Pollen Filter
* Both rear struts replaced with Bilstein ( both were shot )
* Front driver side air suspension bag replaced
identified issues:
Slight Coolant leak from supercharger
Slight misting of oil from rocker covers
Rear brakes nearing wear limit
Post #724487 13th Sep 2025 9:24pm
Glad it's still going well and you are looking after it.... Thumbs Up Bow down Thumbs Up Pete
Post #724497 13th Sep 2025 11:38pm
Driyage
Thanks Pete,
It’s a good car so well deserved to be looks after.
I managed to source a full upper tailgate as the one there is getting really crusty on the bottom edge
Arches need a clean up and spray , but all will be done over winter Smile
Post #724501 14th Sep 2025 6:41am
Bow down
Don't forget to take the sill covers off, and the plastic jacking points and repair or treat as needed... Thumbs Up Pete
Post #724517 14th Sep 2025 10:31am
Driyage
Indeed, all are part of the “planned works”
I think next on the immediate list are the brakes… rears a worn a bit than my liking
Post #724602 15th Sep 2025 6:49pm
That's because the adaptive cruise uses only the rear brakes, use it and the rear pads wear first...! Pete
Post #724683 17th Sep 2025 4:07pm
