Home > Maintenance & Mods (L405) > Failure driver seat massage and function
Page 3 of 3 <123
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
https://www.fullfatrr.com/forum/topic73802.html
Post #724459 13th Sep 2025 11:18am
rk7
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Carpathian Grey
Thank you so much!
I can't believe I didn't see that other post before, it could have saved me the hassle of trying to switch the seat module under the seat. L405 2021 Range Rover Vogue Autobiography P400e
L405 2016 Range Rover Vogue TDV6 - Sold
L405 2019 Range Rover Vogue P400e - Sold
L320 2013 Range Rover Sport SDV6 - Sold
Post #724470 13th Sep 2025 3:18pm
rk7
@zenman apologies for the multiple posts but did you have the same problem as well?
As in the massage seat would stop working after coming on and it would work again after locking unlocking the car? Couldn't see the detailed issue listed in the other post either.
Thank you,
RK L405 2021 Range Rover Vogue Autobiography P400e
Post #724473 13th Sep 2025 3:37pm
zenman63
No mine had inflated bags and they stayed inflated, very uncomfortable.
I do also have the seat module, I bought a new one but it didn’t fix it.
Post #724476 13th Sep 2025 4:37pm
rk7
Hmm… I’m thinking maybe my issue is different then.
As my massage function starts but then stops after 5-10 seconds on anything else other than the upper body setting and the middle 2 packs stay inflated (I have to take the rear seat cover off and unplug the lines to get the air out). And as I highlighted earlier if you do use the upper body setting and it’s run once it won’t start again and none of the lumbar support function will work after either until you lock and unlock the car.
I have a brand new module as well but after replacing, I still have the same issue. Maybe the car needs coding? Everything worked exactly as before with the new module so it makes me think the car accepted the module and the problem is somewhere else.
I’ll make a video later and post it here for reference. L405 2021 Range Rover Vogue Autobiography P400e
Post #724478 13th Sep 2025 5:19pm
zenman63
Have you coded the new module?
It definitely needs it if not.
Post #724513 14th Sep 2025 10:16am
rk7
Sorry that's what I meant. I didn't have it coded.
I replaced it and it basically worked. I had all the same functions work as expected.
Should it be working without coding?
I don't want to replace the module pointlessly if it's not broken. L405 2021 Range Rover Vogue Autobiography P400e
Post #724514 14th Sep 2025 10:19am
zenman63
Is it new or used?
It needs to be the same part number and it works but not properly uncoded, no end points etc, that all needs learning, and the vin number putting in.
Post #724518 14th Sep 2025 10:38am
rk7
It’s brand new.
Maybe it’s worth getting it coded. I'll ask around for a quote. L405 2021 Range Rover Vogue Autobiography P400e
Post #724522 14th Sep 2025 10:53am
zenman63
Iid g4 or dealer spec diagnostic will sort it.
Post #724523 14th Sep 2025 11:07am
Page 3 of 3 <123
