![]() | Home > Technical (L322) > front airbag burst whilst on two post ramp |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1865 ![]() ![]() |
They are absolutely fine to lift on a 2 post lift. No different to jacking up and lifting a wheel off the ground I've even seen them blow in the car park while sat stationary, and engine off ![]()
If finances allow, do them in pairs. If 1 has gone, the other will be in a similar condition
Fine, if the hub bolts are not seized...
Fit OE units if possible. Cheap parts are a bit ![]()
If you are paying labour to replace the bags, if works out at a similar cost to fitting a new complete unit. If you are doing the work yourself, it is cheaper (no labour cost, obviously) |
diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 38 ![]() ![]() ![]() |
My labour is free so open to rebuilding them, where can you get them from? thanks |
