Home > General (L405) > L405 - can you spot a car with a deployable tow bar?
Always
Hi all.
I'm starting to look at an L405 to replace my L322. It seems that very few on Autotrader list the deployable towbar, and I'm unsure whether that is because very few have it, or just that it doesn't get listed...
So my question is: are there any telltale signs to look for that will indicate the presence of a towbar? (Aside from actually being able to see it deployed, obviously!). I'm looking at cars around 2017 / 2018 ish.
Another thought... was there ever a manually removable towbar, such as on the L322, or just the electric one?
Thanks in advance.
Post #724992 23rd Sep 2025 3:15pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
You can tell by the switch pack in the right hand side of the boot . The trim in the bumper also has a cut out too . Detachables have the cut out too. 2019 SV AB Dynamic Scafel Grey
Post #724993 23rd Sep 2025 3:40pm
markwg
Re: L405 - can you spot a car with a deployable tow bar?
I completed my similar search about 2 months ago: you can add " tow bar" into the key word drop down option on Autotrader, that does a good job of flitering in the cars that have it. Many list as having the tow bar preparation but that's a separate option, it doesn't mean they have the bar as well. As above, the tell tails are the buttons in the boot, & the cut out below the bumper. In my experience, it depends which engine you want, the big petrols tend not to have it, whereas with the diesels it's more common; but there are a lot more diesels in the first place, of course.
Post #725015 23rd Sep 2025 11:05pm
CS
There is a farmer's hitch removable towbar option, at least up to MY 2017, mine has that. It's quite a bit cheaper to retrofit and no problem with seizure, though rust needs to be cleaned off the armature if it's not used regularly. Only Range Rovers since 1988
Post #725017 24th Sep 2025 12:20am
Tdtj
Also on the media screen of the later ones it will say deployable tow bar if said seller has taken pictures of the different display 2016 4.4 diesel
Post #725029 24th Sep 2025 11:44am
Always
Many thanks gents. I appreciate the info. Smile
Post #725032 24th Sep 2025 12:59pm
Mike Edwards
United Kingdom 2019 Range Rover Vogue SE SDV8 Mariana Black
Both of mine have the removable section in rear bumper.
It’s the buttons in the boot that differ.
Post #725393 30th Sep 2025 3:02am
you can get a westfalia detachable tow bar for them, its what I've got on mine. not particularly visible when its removed. Works well and is a good option if you can't find one with a deployable bar.
You can just see the deployable bar when it's stowed, but you have to look closely. As above the buttons in the boot are a give away. There is nothing that can't be fixed with a hammer😜😜
Post #725447 30th Sep 2025 8:49pm
