![]() | Home > General (L405) > L405 - can you spot a car with a deployable tow bar? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721 ![]() ![]() ![]() |
You can tell by the switch pack in the right hand side of the boot . The trim in the bumper also has a cut out too . Detachables have the cut out too. 2019 SV AB Dynamic Scafel Grey |
markwg Member Since: 26 Jul 2025 Location: Hampshire Posts: 2 ![]() ![]() |
I completed my similar search about 2 months ago: you can add " tow bar" into the key word drop down option on Autotrader, that does a good job of flitering in the cars that have it. Many list as having the tow bar preparation but that's a separate option, it doesn't mean they have the bar as well. As above, the tell tails are the buttons in the boot, & the cut out below the bumper. In my experience, it depends which engine you want, the big petrols tend not to have it, whereas with the diesels it's more common; but there are a lot more diesels in the first place, of course. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431 ![]() ![]() ![]() |
There is a farmer's hitch removable towbar option, at least up to MY 2017, mine has that. It's quite a bit cheaper to retrofit and no problem with seizure, though rust needs to be cleaned off the armature if it's not used regularly. Only Range Rovers since 1988 |
Tdtj Member Since: 29 Sep 2021 Location: East kilbride Posts: 207 ![]() ![]() |
Also on the media screen of the later ones it will say deployable tow bar if said seller has taken pictures of the different display 2016 4.4 diesel |
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 58 ![]() ![]() |
Many thanks gents. I appreciate the info. |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 282 ![]() ![]() ![]() |
Both of mine have the removable section in rear bumper.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
you can get a westfalia detachable tow bar for them, its what I've got on mine. not particularly visible when its removed. Works well and is a good option if you can't find one with a deployable bar.
