Home > Technical (L322) > 3.6 TDV8 Oil Cooler/Filter housing seal replacement
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
It’s been a while since I’ve posted but I’m replacing the seal between the oil filter housing and block on my 3.6 TDV8 engine and I’m struggling to find the torque figures for the bolts that hold the housing down to the block.
I can’t see them in the manuals in the wiki, so just wondered if anyone happened to know what they should be tightened to?
Thanks,
Jamie
Post #725325 29th Sep 2025 12:14pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
When I did mine I used 8Nm the reccomended m6 into aluminium setting.
Post #725335 29th Sep 2025 1:48pm
Jamiehol
Thanks, I’d got as far as in the absence of anything else using a figure of 10Nm as that is what the M6 sump bolts are.
Post #725350 29th Sep 2025 5:12pm
