![]() | Home > Technical (L405) > Im going to spoon my own eye out...... ! |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1053 ![]() ![]() |
1mm more tread or only 1mm of tread ? |
whippeteer Member Since: 29 Sep 2025 Location: Crowborough Posts: 3 ![]() ![]() ![]() |
Ooops, yeah, 1mm more than the tyre swapped out |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1430 ![]() ![]() ![]() |
Wheel bearing needing replacement? Mine had that recently and it was a howling sound. LR says not to rotate the tyres round the car. Only Range Rovers since 1988 |
Wheel bearing was my first thought although i keep being told that its not that. I have read that even if the bearing is knackered it may not present the standard symptoms when rocking the wheel / turning etc.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 704 ![]() ![]() ![]() |
If it's not moving as you rotate the tyres you're likely looking at a bearing.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 603 ![]() ![]() ![]() |
There’s a Range Rover owner on YouTube (raymies garage) he has got several videos of him trying to find out the same noise as what you have got …..wheel bearing in the end ,I would be looking at replacing it if it was me if you have tried swapping the wheels over and is still the same. L405 2014 Loire blue Autobiography |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
If they are foam filled silent tyres then it could be the foam that’s come loose - yes it does happen and can also cause a vibration - don’t ask how I know - took ages to track it down. Now I will not buy tyres with foam in - I can’t tell the noise difference anyway! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
if the noise stayed where it was when the wheel was changed then don't think that's the problem (could be wrong tho ) L405 2014 Loire blue Autobiography |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389 ![]() ![]() |
I had this. LR main dealer diagnosed a Transfer Case.
