Home > Technical (L405) > Im going to spoon my own eye out...... !
whippeteer
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
8 days, 3 different garages. Droning noise from front wheel (believe its passsenger side) starts at 30mph and sounds like FAA FAA FAA FAA FAA almost like theres a flat spot on the tyre. Gets faster with speed.
2 of the garages said could be the tyre on the passenger front as its slightly lower tread but all checks on bearing, pads, drive shaft etc all seem perfectly good.
3rd garage said they couldnt even hear the noise. Its driving me MENTAL ! its so clear and loud.
I asked the 3rd garage to swap the passenger front with passenger rear just to rule out the tyre and now its maybe slightly worse. This tyre has a bit more tread maybe only 1mm more but the steering wheel is now edging slighty towards the left, passenger front. No vibrations, nothing at all just a god awful noise that is slowly driving me insane.
Post #725342 29th Sep 2025 3:33pm
Gsxr1250dave
1mm more tread or only 1mm of tread ?
Post #725343 29th Sep 2025 3:34pm
whippeteer
Ooops, yeah, 1mm more than the tyre swapped out
Post #725344 29th Sep 2025 3:38pm
CS
Wheel bearing needing replacement? Mine had that recently and it was a howling sound. LR says not to rotate the tyres round the car. Only Range Rovers since 1988
Post #725349 29th Sep 2025 4:55pm
whippeteer
Wheel bearing was my first thought although i keep being told that its not that. I have read that even if the bearing is knackered it may not present the standard symptoms when rocking the wheel / turning etc.
My worry is now that how much diagnostic cost is this going to rack up when it could be the bearing, drive shaft bearing, differential etc etc. I understand that i will have to go through the process and replace each part as i go until it stops Sad
Post #725351 29th Sep 2025 5:24pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
If it's not moving as you rotate the tyres you're likely looking at a bearing.
Play in the bearing that you can detect it while wobbling the wheel harks back to the old tapered roller bearings or a huge failure where play was common and you could sometimes dial it out.
Modern bearings start to fail with a light rumble or whine and it's not always constant. With other noises the harmonics can sometimes sound sureal and often an iregular whine and as you say, apparent flat spot which would indicate the bearing running surface is ovaling.
Only way to really tell is jack it up and rotate the wheel using a stethescope to listen, you'l hear it if it's on the way out, a rumble or light grinding sound.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #725352 29th Sep 2025 5:40pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
There’s a Range Rover owner on YouTube (raymies garage) he has got several videos of him trying to find out the same noise as what you have got …..wheel bearing in the end ,I would be looking at replacing it if it was me if you have tried swapping the wheels over and is still the same. L405 2014 Loire blue Autobiography
Post #725354 29th Sep 2025 6:13pm
Vogue
If they are foam filled silent tyres then it could be the foam that’s come loose - yes it does happen and can also cause a vibration - don’t ask how I know - took ages to track it down. Now I will not buy tyres with foam in - I can’t tell the noise difference anyway! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #725362 29th Sep 2025 7:59pm
will308f
if the noise stayed where it was when the wheel was changed then don't think that's the problem (could be wrong tho ) L405 2014 Loire blue Autobiography
Post #725394 30th Sep 2025 5:56am
j_rov
I had this. LR main dealer diagnosed a Transfer Case.
Warranty company told them to FO and keep looking. They decided it was the wheel bearing in the end. Noise gone now! __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #725555 3rd Oct 2025 4:07pm
