|  | Home > Technical (L322) > 4.4 TDV8. Coolant replace. Do I need to use a vacuum pump? |
| Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 93      | Yes, definitely.
|  6th Oct 2025 11:05am |
| Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 44    | Thanks Shaun.
|  6th Oct 2025 11:53am |
| Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 93      | Sorry, Ben. I should have referred you specifically to the 2010-12 Workshop Manual in the wiki.
|  6th Oct 2025 4:14pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | remember to wash and clean the small radiator behind the front wheel arch, often called the Auxiliary Radiator, often neglected at routine coolant changes
|  6th Oct 2025 4:39pm |
| Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 44    | So valuable thanks all.
|  7th Oct 2025 1:40am |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | I used a Karcher ( pressure washer ) to clean all the old dirt and road muck off the outside of the aux radiator, and ran a garden water hose through the rad for 2 or 3 mins, inside of the rad was ok, but the outside was very dirty, which is why I suggested you look at it being in Oz  | ||
|  7th Oct 2025 12:22pm |
| Posting Rules
