Home > Technical (L322) > 4.4 TDV8. Coolant replace. Do I need to use a vacuum pump?
Benji1
Australia
Hi All,
Looking to drop and replace the coolant in my 4.4 TD 8. Can I do this without a vacuum pump?
Post #725643 5th Oct 2025 12:33pm
Shaun_
Yes, definitely.
I did it mine a few months ago. I used exactly the same method I've always used on any car - draining from the bottom and then topping up slowly and letting the car get up to temperature and allowing it to vent trapped air from the top as per the wiki. I expected to have to repeat the venting procedure several times but didn't have to and it's been perfect since. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #725696 6th Oct 2025 11:05am
Benji1
Australia
Thanks Shaun.
Had looked for this in wiki but could not find it.
Can you point me in the right direction for the entry please?
Ben
Post #725697 6th Oct 2025 11:53am
Shaun_
Sorry, Ben. I should have referred you specifically to the 2010-12 Workshop Manual in the wiki.
Refilling with and without using a vacuum pump are covered in separate sections. Although it talks about partial draining and filling as I said I drained mine right down and followed the non-vacuum process and it worked fine.
It comes under Engine > Engine Cooling > Cooling Gen Procedures > Cooling System Partial Draining, Filling & Bleeding.
Hope that helps.
Regards
Shaun 2012 TDV8 Westminster in the New Forest
Post #725715 6th Oct 2025 4:14pm
pcourtney
remember to wash and clean the small radiator behind the front wheel arch, often called the Auxiliary Radiator, often neglected at routine coolant changes
Due to package constraints an auxiliary radiator is required to maintain acceptable coolant temps under arduous driving conditions such as high-load and high ambient temperatures. This radiator is located in the in the RH wheel arch area, with cooling airflow supplied by a dedicated aperture in the front bumper. The auxiliary radiator is connected in parallel with the main radiator, with the coolant flow being controlled by the main engine thermostat.
Post #725717 6th Oct 2025 4:39pm
Benji1
Australia
So valuable thanks all.
pcourtney - what is the method you use to clean out the auxilliary?
Post #725730 7th Oct 2025 1:40am
pcourtney
I used a Karcher ( pressure washer ) to clean all the old dirt and road muck off the outside of the aux radiator, and ran a garden water hose through the rad for 2 or 3 mins, inside of the rad was ok, but the outside was very dirty, which is why I suggested you look at it being in Oz Smile
NB I had to take the front RH wheel off to get good access.
Post #725756 7th Oct 2025 12:22pm
