![]() | Home > Technical (L322) > 4.4 TDV8. Coolant replace. Do I need to use a vacuum pump? |
| Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 93
Yes, definitely.
| Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 44
Thanks Shaun.
Sorry, Ben. I should have referred you specifically to the 2010-12 Workshop Manual in the wiki.
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032
remember to wash and clean the small radiator behind the front wheel arch, often called the Auxiliary Radiator, often neglected at routine coolant changes
So valuable thanks all.
I used a Karcher ( pressure washer ) to clean all the old dirt and road muck off the outside of the aux radiator, and ran a garden water hose through the rad for 2 or 3 mins, inside of the rad was ok, but the outside was very dirty, which is why I suggested you look at it being in Oz |
| All times are GMT |
