![]() | Home > Technical (L322) > 4.4 tdv8 2012 oil leak under |
| fatu Member Since: 02 Feb 2024 Location: Prague Posts: 48
| Fla Member Since: 26 Nov 2023 Location: South west Posts: 194
Sorry if I am stating the obvious but was the underneath of the car and the back of the engine thoroughly flushed clean after the oil cooler change. I know with mine I had to spend hour using brake clean to mop up and flush all the old oil that had sat on the engine block from the previous owner neglecting to change the oil cooler. Also, I imagine the tiny O rings were replaced on the return pipe, sometimes that can be skipped by shops. Current yokes
I suspect that as well, it was a good landy shop… costly…i trusted them but another appointment made to question this the same thing. They are just 2 weeks later so I am being impatient also not sure they will accept any wrong doing or so but I will try. I just want to understand that it would still smell oil in cabin or around car in garage if this was the case after 5-6 months, no? It still seems to me something recent. It seems also a lot of oil which puzzles me that I am not seeing any change in oil levels. Range Rover 2012 4.4 TDV8 - current
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
This might be a bit of a long shot but my car got very wet under the front when the steering rack had a serious leak. |
So it is turbo…left side on left side driver model. Second turbo also known as, booked to be changed…another big expense the same year after oil cooler. I could debate to keep it as it does not kick in anyway until 2500 rpm but there is always the risk of ending the engine on highway when passing a car. Still loving the car… Range Rover 2012 4.4 TDV8 - current
