Home > Technical (L322) > 4.4 tdv8 2012 oil leak under
fatu
Czech Republic 2012 Range Rover Vogue TDV8 Sumatra Black
good day, I have recently got my oil cooler changed 3-4 months back. Oil mixed in coolant, classic oil cooler job. All is fine $$ spent. And now I have oil under the frame, not yet a drop on the ground but I see the drop as in the photos. I suspect I pushed the second turbo (which I do this time to time to get rid of the oil sums up there) like few seconds of white smoke and then all is fine. Still driving perfectly fine month goes by but I see the oil at the bottom still. No oil lost, I checked the oil levels, no coolant lost and no mix of oil in coolant. No error code or limp mode even when I push over 3k. What can this be? Any usual shop says second turbo change it…I am not convinced but any advice is welcome. Range Rover 2012 4.4 TDV8 - current
Range Rover 2008 3.6 TDV8 - previous
Range Rover 2004 3.0 TDV6 - previous
Post #726099 13th Oct 2025 7:02pm
fatu
Post #726100 13th Oct 2025 7:04pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Sorry if I am stating the obvious but was the underneath of the car and the back of the engine thoroughly flushed clean after the oil cooler change. I know with mine I had to spend hour using brake clean to mop up and flush all the old oil that had sat on the engine block from the previous owner neglecting to change the oil cooler. Also, I imagine the tiny O rings were replaced on the return pipe, sometimes that can be skipped by shops. Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #726117 13th Oct 2025 10:03pm
fatu
I suspect that as well, it was a good landy shop… costly…i trusted them but another appointment made to question this the same thing. They are just 2 weeks later so I am being impatient also not sure they will accept any wrong doing or so but I will try. I just want to understand that it would still smell oil in cabin or around car in garage if this was the case after 5-6 months, no? It still seems to me something recent. It seems also a lot of oil which puzzles me that I am not seeing any change in oil levels. Range Rover 2012 4.4 TDV8 - current
Post #726130 14th Oct 2025 9:42am
kevinp
This might be a bit of a long shot but my car got very wet under the front when the steering rack had a serious leak.
Post #726131 14th Oct 2025 10:00am
fatu
So it is turbo…left side on left side driver model. Second turbo also known as, booked to be changed…another big expense the same year after oil cooler. I could debate to keep it as it does not kick in anyway until 2500 rpm but there is always the risk of ending the engine on highway when passing a car. Still loving the car… Range Rover 2012 4.4 TDV8 - current
Post #726652 22nd Oct 2025 8:04pm
