![]() | Home > Maintenance & Mods (L322) > 3.6 TDv8 / ZF6HP26 Gearbox Oil Change |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
Having replaced my gearbox sump & oil at approx 124k and then flushed it with petrol to see what was inside the filter I found almost nothing.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 603 ![]() ![]() ![]() |
im looking for these myself but still pretty new to the gap tool ....could you point me in the right direction please thanks will L405 2014 Loire blue Autobiography |
RG2024 Member Since: 08 Oct 2024 Location: Warwickshire Posts: 43 ![]() ![]() ![]() |
Followed the procedure. Pumped around 3 litres in cold before it started coming back out, started the engine, cycled the box etc& ended up getting the full 7 litres in with nothing given back. Reminded me of feeding my lad as a baby. Should I be worried? I was wondering where it was all going. I did fetch the valve block down & I did the oil cooler pipes as they’d been leaking so probably drained more than my fair share. Tempted to take it for a little spin & see how it goes.
Panic over. Ordered an additional 2 litres. Pumped in around an extra 0.5 litres last night before it started coming back out of the fill hole, so it seems logical that changing the cooler pipes meant it needed that extra drop more. Worth noting if you plan to do that job at the same time. '95 VW Corrado VR6
spotwazere Member Since: 12 Oct 2025 Location: Witney Posts: 1 ![]() ![]() ![]() |
