![]() | Home > In Car Electronics (L322) > DAB radio module |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 703 ![]() ![]() ![]() |
Many thanks, I'll look into that idea.
Jimnic007 Member Since: 13 Aug 2019 Location: Cheshire Posts: 80 ![]() ![]() ![]() |
Hi Jonny,
barbel jim Member Since: 17 Mar 2025 Location: Northamptonshire Posts: 13 ![]() |
From my experience every time you go back to dab +…..
Thanks Jim,
The most fiddly bit is bolting the new module back in. I ordered a jag plug with tails, then cut the old plug off with 50mm tail and crimped the new one on. Relatively simple to revert back if ever needed. Best mod ever for a l322 |
Before I disconnect anything, do I need to disconnect the battery or take any other precautions, so that I don't blow anything up??
No need to disconnect battery…. They’ll be fuse protection. Make sure the ignition is off and just cut the wires one at a time, and keep away from metal, the red positive especially |
